Hi, you'll hopefully find it's either the ECU or the speed sensor, have you still got a speedo? I had exact same problem with Vento auto when speedo failed took the VW man 2 weeks to locate fault as I had several and he had to work through the diagnostics to remove fault code, second hand ECU was $250 and speed sensor brand new was around the $130 mark.
