Results 1 to 4 of 4
Thread: Getting my headlight covers off ..
    May 2009
    Eastern Melbourne
    Hello dubbers ,,
    I've had loads of people reccommend I lose the headlight covers on my MkIII golf ..
    Im read to do it , but how ?? I dont wanna just go undoing things till it all falls apart ..
    Anyone got a diagram or a handy till howto on this subject ?
    MKIII Golf - Got any Blacker ?
    97 Build - 16" Lite 9's - GPS - 60GB Glovebox
    Sep 2006
    West Sydney
    Check to see if they're clipped in to the edges of the headlight lens. If not, then they may be stuck on with silicon or somethin'... Heat them up with a heat gun or pop them in the oven for a minute then try and gently pry using a taped up flathead so you won't scratch the lens. I remove headlight lens this way so it should be more than enough to remove those headlight masks if they're glued on.
    May 2009
    Eastern Melbourne
    They are clipped on the front ..
    I sort of see how they come off, it just looks as if i have to remove the grille too .. just wanting to make sure there wont be any important bits to keep note of before i pull it all apart ..
    May 2009
    Eastern Melbourne
    This is what i currently have on the car .. the pic is a bit nasty but you get the idea ..
