do it, looks so much better..... it won't help aim your lights though, you need to adjust them from behind with the adjuster knobs........
What do you guys think of putting a factory dual beam headlight lense on a aftermarket projected head light would that look weird because my headlight dont aim right?
94' Golf Mk3 Vr6
I Joey modded my mk4 look a likes and have cl glass on them. It's certainly different. But way better than clear headlights in my opinion.
my height adjustment is okay but the cut off line is ridiculous . i bought them off cheapbay from the states and had to open them up and rotate the plate in front of the projector lense to make it a rhd headlight .ive got HIDs in them which makes it really bright but you'll hate to drive in front of me on the free way if im on the far right lane. the beam is like a boomerang
94' Golf Mk3 Vr6
yeh ima joey mine but a little differently to the norm, should look ok with any luck.....
not sure I follow, the cut off is the height isn't it? you said you swapped the internals to make them kick up to the left instead of the right no?..... also how is your american lights fitting to our euro support?!
yeah basically to my understanding the cut off is the straight line on the main beam and has a 90degree L at the start on australian headlights that kind of looks like this ( \______ ) but on the american headlights the cut of is like this _____/ this bit ( \ ) focuses on the footpaths on our roads. you can actually see your cut off line when you come up close to a wall or a garage door . the headlight housings are the same its only the cut off line/beam that changes.
but even though i turned the cut off line plates inside the headlight its still not 100% and my main beam focus is not in centre but more on footpaths if that makes sense . i think im going to buy the original dual beam headlights if i cant fix them
94' Golf Mk3 Vr6
yeh k, well as a general rule oem is best when it comes to euro styling so go that route when you can![]()
yea thats what i was thinking and im over my hid setup the car has enough attention as it is. also my yellow block fogs are horrible im going back to oem with those might just get the dark tinted indicator and reflectors and yellow tinted oem fogs .
94' Golf Mk3 Vr6
^^sounds ace
So i've started on the new headlights...everyone's out so the oven is mine! haha
