Results 1 to 5 of 5
Thread: Gearbox selector out of sync
    SE Suburbs, Victoria
    Got stuck in the eastlink tunnel last week. I went to change gear and I lost all drive, no gear would select.
    I feared the worst but it seems that after a fiddle around it may be a problem with the gear selector and not the gearbox (thank god).
    I've been able to get the gears in sort of. i was able to go for a test around the block but the gears still seem to be having a hard time grabbing the gears.
    Has this happen to anyone else and how do i fix it?
    I have the 02A trasnmission.
    Haynes manual says go to a VAG dealer cos there is specially machined jigs required...
    Cheers.
    Jan 2010
    Is there any play in the gear stick? If so it might be the relay shaft ball = 10 mins to replace & around $30.
    2.0 Shifter Rebuild
    I believe that's the wrong gearshift, I need 02A.
    I found a vid of what mine it was doing on mine, and the same type too
    but the links in the vid lead to doing a 02J swap which isn't what i need atm.
    I found the problem though.
    The spline on the shifter lever and the selector shaft are worn out.
    The Part Number is: 1H0 711 053 A
    But I even rang up the VW dealership (Burwin) and they couldn't even find the diagram of the 02A tower.
    So i'm a bit stuck to where to find this part..
    otherwise i need to find a place that can re-spline this part.
    If anyone knows anything that may help, that would be great.
    Dec 2008
    Sydney/Canberra
    If you can supply them with the part number, there's no reason why they can't run a search on it to at least get a price.
    To re-spline it, you'd need to close the hole up and re-bore before you can spline it. You'd have to do similar to the shaft.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2012
    sydney, NSW
    yo did you check the shift link bolt that goes through the shift linkage closest to the battery, i just replaced that bolt 15bucks all my shift problems are now sorted..
