Results 1 to 10 of 10
Thread: gearbox change over
    Sutherland Shire, Sydney
    gearbox change over
    Just wondering if anyone has had experience or has changed the mk3 Vr6 gearbox to a 02M mk4 6 speed manual?
    or if there is any other 6spd that will fit in a mk3 vr6??
    Chris
    95' golf VR6
    Gosford Central Coast NSW
    Is the gearbox you are thinking of from a 4 cylinder car? If it is, then no, it wont fit as is.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    would the r32 gearbox not fit? if it were the manual.
    I'm pretty sure someone has done it on the vortex forum but I'm not sure if it was the gearbox from the jetta or the r32
    95' golf VR6
    Jun 2007
    Eastern Suburbs Melbourne
    not sure if it would work because the O2M is a 4WD gearbox.
    i like volkswagens
    Sep 2006
    West Sydney
    It's the 5 speed 02J from the GTIs. I believe mk3pete has done the conversion, along with many others on the Vortex. Not an overly complicated conversion from what I've read, you just need the correct parts to make the changeover. Search vwvortex.com for DIY threads.
    Sent from my iPhone using Tapatalk.
    Jun 2007
    I'm pretty sure sneakypete just has the tower/shifter/cable conversion. I do believe he's still running an O2A box.
    i like volkswagens
    Jun 2011
    R32 o2m will bolt up. Just needs a trans mount done, think there is now a kit made for it.
    There is one for sale now, Dragon green one that has the V5 Bora box in it that has shorter ratios.
    Dec 2007
    Girraween
    None of this makes sense so will clear it up
    02M gearbox is the larger sized manual gearbox found on V6 Bora, R32, TT with 165kw engine etc
    The V5 Bora does not have an 02m gearbox, its still the O2J
    To do the conversion you will need the following:
    02m gearbox
    Casing plate to remove transfer case
    subframe mount cut and re-welded as it gets in the way of the driveshafts
    custom driveshafts as the gearbox couplings are different and ends are different not to mention lengths
    Bracket for gearbox mount
    hydraulic lines for clutch slave cylinder
    complete linkage assembly off 02m gearbox
    Im sure I missed some bits...
    Question is why do you need it?
    My own car will have over 500HP so its bordering on the safe limits for the 02a
    If you want the extra gear look into a gearset kit, much cheaper
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
    yeah thanks thats sweet,
    I was just looking into a 6th gear for the future if i were to do anything with the engine, plus all i'm doing at the moment is highway driving 4 days a week so it annoys me there is no 6th gear to cruise in, for now the gearset looks the best option...
    95' golf VR6
    Jan 2011
    Rooty Hill, Sydney
    there is someone on here that has done a 6speed conversion, just carnt think of the name rite now, it'll poop in my haed later.
    Garage:
    VR6
    XR6
    R36
