Results 1 to 7 of 7
Thread: Front Off ??
    MK3tdI Guest
    Front Off ??
    i've been told that the easiest way to get at the motor to change the clutch is to remove the entire front end from the car - is this an easy task ??
    My 94 Mk3 TDi needs the clutch doing and I'll change the front shocks and mounts at the same time.
    Just wondering whats involve rather than stuffing my back up !
    Jools
    Aug 2006
    Skye, Victoria
    i think there is a how to somewhere in the mk3 section, if not try searching the tex.
    Feb 2006
    Camberwell, Victoria
    To get the front off, undo the bolts where the red dots are.
    Where there are blue dots, you'll have to undo plugs for horns, lights twist connector thingy, hood popper cable. You'll also have to undo the radiator, and air con condenser. When you undo AC, be careful of the gas, and don't breathe it in...
    There are also some clips to hold the wheel arch plastic guard in place, and when putting the bumper back on, make sure you line up the bumper slots near the wheels...
    Hope that helps...
    MK3tdI Guest
    Neat
    thanks golf3, that has to be so much easier, i'm wondering if its possible to do it without disturbing the gas condenser, being a diesel I expect there is a bit more room compared to the motor in your photo !
    Jools
    Quote Originally Posted by MK3tdI View Post
    Jools
    I wouldn't take the front off to do the clutch. It's not that big a job to get to everything with the front fitted. I don't know of an VW shop in the UK that would do it that way.
    Camden, Sydney
    Yeah the diesel box will be heavy, so have a helper, but I wouldn`t take the front off either.
    Drop the subframe down an inch on that side when you need too
    Sep 2006
    Banff, Canada
    If you need a more detailed step-by-step on removing the front (up to a point) if you are ABSOLUTELY sure you need to, I wrote one up with detailed photos that could be of help...
    http://www.vwwatercooled.org.au/newf...ead.php?t=2974
    Have fun Sounds like a mission!
    Cheers!
    JHN
    Canadian dubs coming to VWwA soon
