Results 1 to 3 of 3
Thread: Front fender removal?
    May 2012
    Perth, Western Australia
    I managed to find a cheap replacement front passenger side fender, I am planning on removing my stock one and replacing it with a sticker bombed fender. Is there anything I should look out for when removing the fender? Is it fairly straight forward or is there any hidden bolts I should be aware of? Cheers in advance guys
    remove the arch liner, all the rest of the screws are obvious.
    I had some trouble with the glue holding the top of the guard down, in the end I managed to 'slice' the glue using fishing line as you would debadging the back of a car.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Sep 2009
    If I recall correctly I used a heat gun to soften the glue on the top of my fenders, makes them easy to pull off (after you've taken out all the bolts ofcourse)
