Results 1 to 10 of 10
Thread: Front End Vibration
    Anonymous Guest
    Front End Vibration
    Any ideas about Front End Vibrations on 97 Golf M3 GL 2 Litre 103,000k's.
    Had new tyres fitted,on car balance done,rotated wheels, Tyre company did notice slight wobble inside front hub. Vibration is felt through floor at 60 kph & through steering wheel at 100 kph. Front Hubs or Wheel Bearings ?
    Camden, Sydney
    Check that the subframe is done up tight underneath.
    Try lifting each front wheel and spinning them and rattle them back and forth. Any play is bearings.
    syncro Guest
    Sounds like tyre balance. Maybe one of the weights has fallen off.
    20v kit car Guest
    is the golf auto or manual???wheel bearings won't cause a wobble...tyre rim or c/v joint will......on a mk3 auto its common for the rh inner c/v to sh*t itself ,usually at low speed say 15kmph let go of the steering wheel and observe if it has movement back and forth...if so bingo check the cv's cheers steve
    20v kit car Guest
    is the golf auto or manual???wheel bearings won't cause a wobble...tyre rim or c/v joint will......on a mk3 auto its common for the rh inner c/v to sh*t itself ,usually at low speed say 15kmph let go of the steering wheel and observe if it has movement back and forth...if so bingo check the cv's cheers steve ps at 100thou the upper strut bush is US it will also need replacement..their not expensive
    Anonymous Guest
    Golf M3 GL 2 Litre Manual Front End Vibration
    Car is a 5 Spd Manual
    imported_brackie Guest
    Registering
    Hey, Mr "Guest"! How about registering! If we are of any use to you it's worth the effort.
    Anonymous Guest
    Front End Vibration
    Vibration looks like being a bent L/H Drive Shaft.
    Golfwise Guest
    wheel wobble
    Thats strange to have a bent axle and nothing else.
    Go for it .Register !!!! We don't bite much.
    Re: wheel wobble
    Quote Originally Posted by Golfwise
    much being the operative word
Similar Threads
  1. MK3 front grill
    By Golf Houso in forum Mk3 Golf & Vento
    Last Post: 02-07-2009, 08:27 AM
  2. How to tell difference between 1.9 and 2.0 TDI?
    By brenno in forum Mk5 Golf & Jetta
    Last Post: 07-05-2007, 12:55 PM
  3. Arrh Smashed the front lip into a gutter.
    By Subie25L in forum Mk5 Golf & Jetta
    Last Post: 20-03-2007, 12:22 PM
  4. OEM 25th Anniv Front & Rear valance
    By jbot in forum Mk4 Golf & Bora and New Beetle
    Last Post: 21-02-2007, 08:59 AM
