Vaseline looks disgusting, but good work Louis!
Is your front door lock freely spining and will not lock ? Most likely it is the hook on the Connecting rod is broken.
It was a breeze to change. I got my Heavy Duty lock set from Tooleys for ~$80. It was a bit pricey as it is a modified heavy duty verion of the OEM lock set.
DIY time ~ 1 hr.
Disassemble door handle from door, use allen key. ( Note no need to remove door card nor window regulator, THANK rayray086)
Firstly, the locking mechinism on the lock excentric must be transplanted, this can easly done with a long nose pliers.
Transplanting Spring from OLD
To New
Lubed up. Note: DO NOT USE WD-40!!!! Lock mechanism will violently eject when pulling key out. pain in the azz to line inorder again. Use Vaseline instead !!!!!
Lube up key with vaseline and insert into key hole a few times.
Assemble lock as per picture. (Thanx vortex)
Ghetto touch up.
Assemble into car.
The thing you have labelled as the lock eccentric is in fact the barrel.
The lock eccentric, or connectiing rod is no 15 on that diagram. That is the bit that usually breaks and can be replaced on its own.
Otherwise nice writeup.
Any tricks to remove the door handle itself louis? Specifically the metal tab part which hooks onto the plastic door handle?
They paddle eccentric can only be bought as bigger, thicker one from VW, the old type was superceded mate. FUnny thing i found with them is that people force the lock round against its will. Really you only need to give the lock a quick flick as the lock has a microswitch. The microswitch only needs a slight tap to trigger. If you are ever stuck you can put the passenger one on to get you out of trouble.
JMAc
Alba European
Yeah thats right!!!!!!!
JMAc
Alba European
