Results 1 to 10 of 14
Thread: fog lights and blinker unit 94 vr6
    Feb 2008
    mOOROOLBARK
    hello people wondering which wires are the low beam wires that run into the head lights so i can T off from the low beams to my fog lights if thats a bad idea please let me know
    Aug 2007
    Mate on your headlamps there is a yellow and a white wire. rule of thumb on Porsche ,Audi and Vw the White wire at the headlamps are high beam and the yellow is low beam. If your splicing mate for other lamps do so with a 5 pin relay as you may overload your switch, thats the only dram you can have.
    Alba European
    Camden, Sydney
    Dont have the fogs on permanently with the low beams, as that is illegal.
    Jul 2007
    Canberra
    I think legally you have to have them hooked up to the high beam AND have a separate on/off switch mounted on the dash from memory
    Forever blowing bubbles.
    Feb 2008
    mOOROOLBARK
    very helpful guys if thats the case il wirer it to the relay then to a seperate switch my, is it true the 95 vr6 came with a light toggle on the blinker lever
    Jul 2007
    Canberra
    Some (i think only overseas models) came with a fog light switch as part of the main headlight switch, you can pick these up for around $50 and upwards on ebay UK and it just replaces your standard headlight switch but has the extra function. You'll find them mostly in the UK as you need to get one for a right hand drive vehicle, lefties are opposite way round.
    One of these fellas:
    http://cgi.ebay.co.uk/VW-GOLF-MK3-HE...QQcmdZViewItem
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Pullstarter View Post
    High beam and fog don't mix.
    Spot lights/driving lights fall in that category, fogs just need a separate switch. (although it may need to be on with at least parkers).
    Feb 2008
    mOOROOLBARK
    no worries thx guys
    Jul 2007
    Canberra
    Sorry my bad, was thinking spotties.
    Aug 2007
    We used to remaove the 1 stage headlamp switch and fit the dual with some extra wiring on some, there is a Vw part number for this, it was a common ask when we were pre delivering these vehicles along with a string of other goodies.
    Alba European
