That's only a rear fog switch. You need the euro one that has two little fog light pictures like mine
Identical to this one except RHD.
Past - '95 VW Golf MK3 VR6
Then u don't have a fog light switch. Which means u most likely won't have any wiring for the fogs.
Are u sure your one looks EXACTLY like that ? (Except its rhd)
Do u have a plug hanging behind the places where the fog lights get placed in ?
Pics ?
Haha u got your answer, never mind my post. U have a standard golf headlight switch.
You don't need a euro switch to fire up the front fogs. I have the stock single pop switch like stef has posted above and it powers my fogs fine. But that doesn't mean you'll have the wiring harness.
Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
Does the wiring harness include cables that run to the front? because I have those cables hooked on the left and right lower plastic grills things just below where fogs should go. The cables are plugged into a socket that prevents them from dangling about.
As I said before though, I'm getting 3V from these cables so they must be connected at least to something.
That's the outside air temp sensor, use the MFA button on the windscreen stalk and it'll show u the outside air temp.
The one u have on the passenger side I've never seen before, so know idea what it is, could be the same as the driver side one.
Plugs for the foglights can't extend down to the plastic grills below.
...whoops. Saw kits on eBay that used the lower grills as a fog and assumed they got power from these, the connector looked identical. I should probably check what things are before plugging stuff in.
At least the mystery is solved. Thanks.
A work around would be using the rails from the rear fog to power some front fogs, but that could get messy.
Looks like I won't be getting fogs any time soon then.
Use a multimeter to find which pins behind the switch give power to the rear fogs. Then run wires from those pins to fogs.
A few people have done it already.
