Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Fog Lights
    Mar 2014
    Bundoora, Victoria
    Fog Lights
    Thinking of some fogs.
    I have the switch, I have the wiring harness already installed.
    I know I need relay 110.
    Is eBay the best place to get them? Why does it seem that the fogs available will leave a gap?
    The front panel has 3 sections. One for the indicator and the other two are covered by one 2 section covering dummy.
    This dummy would come out but the fog lights I've seen are only 1 section wide and would leave an empty spot. Am I supposed to get 1 section wide covers?
    Couldn't find much about this, wondering if anyone has installed them.
    Past - '95 VW Golf MK3 VR6
    Mar 2011
    Inner West, NSW
    Don't need relay 110 - that's for US models.
    Yes there will be a gap so you'll need to purchase a "tow-eye cover." (I actually need a set too because I lost mine).
    Ad for the fog lights themselves, try find some Hella ones - the Depo ones from Latvia off eBay are questionable...
    Sent from my Nexus 5 using Tapatalk
    Mar 2014
    Bundoora, Victoria
    I'm only getting 3V out of the fog light cable when the fog switch is on and the car is running. Is it supposed to be this low? I thought it'd give 12V. Hence why I thought I needed a relay.
    I found some "oem style" ones from China that look to be almost identical to the oem ones, they're not the cheapest either so I assume they can't be that bad.
    Mar 2011
    Inner West, NSW
    Hmmm. Do you have the little metal jumper where #110 is supposed to be in your fuse box? Also check that you have a 10V fuse in slot (10?).
    I've got #110 and had no need for it as it only allows fogs to be used with headlights and not parkers and headlights.
    Eh, its mainly build quality and wiring that I don't like about the imitation stuff. I had polarity issues with the Depo ones I bought
    Mar 2014
    Bundoora, Victoria
    I have a horizontal jumper where #110 is supposed to be. I do have a 10A fuse for the fogs and I've checked it and it's fine.
    Mar 2011
    Inner West, NSW
    Okay. Does it go from bottom left to top right? That's what I've got paired with the 10v fuse and it all works fine.
    Mar 2014
    Bundoora, Victoria
    ok, I was looking at the wrong fuse. The one for the fogs is a 15A 32V. It's the stock fuse. Shouldn't make a difference since a fuse is only there to break if the current goes above its rating, it doesn't actually have any resistance right? (and hence a voltage drop across it).
    It looks like the horizontal one in this photo or as it's labelled here as "bridge".
    Mar 2011
    Inner West, NSW
    Exact same setup as mine. You should be set to go
    Mar 2014
    Bundoora, Victoria
    I'm stumped. Tried a simple 12V light attached to the connector and nothing. Tried all types of lighting combos on the switch and headlight and car running and car off. I can run this light off a 12V battery fine.
    I'm out of ideas, unless both sides have to be connected? but that wouldn't make sense because one of your fog's globes could stop working and then both would be out.
    What gives?
    By the way, the green fog indicator light on the switch does light up if that means anything.
    Jan 2011
    Rooty Hill, Sydney
    Take a pics of your headlight switch.
