That one in the grill is plug and play and i have one set in my vr6 for about 2 years - working like OEM.
Looking at getting some foggies for me Mk3. I have the switch that pulls out and turns on an orange light. Will this turn on front foggies or rear ? Do I need a new switch ?
Are the kits on ebay the easiest way to go about getting the foggies ? Ive seen the ones that have the lens and bulbs installed in the grill for 50 bucks... Are they plug and play and ready to go ?
Cheers.
1996 Golf GL Mk3.
R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
Do a search, it has been covered on here many times, you need the European (not the US it does not fit) switch which pulls out twice once for rear and once again for fronts, there are websites that sell the loom which plugs in to the main loom behind the radiator, I used Eurowires, or you can make your own.
Mk3 Golf Tdi about to sell
Mk 1 Golf GLD somewhere in a paddock!
Mk1 Golf Cabriolet
MK2 Golf Turbo diesel engine and 5 sp gearbox
That is correct "sparkie" amd now you can find very cheap euroswitch from e-bay (but be careful you need RHD).
