Originally Posted by
vrsix
I have this switch in my vr. Don't know if it came standard or if it was put in at a later date. Pull the switch out one click for fronts (which I don't have but would like to do at one stage.) and two clicks for the rear. Rear seems to be just on one side? Is that normal?
Rear fog should be on the drivers side only.
But you can modify the passenger side if you have a bulb spot for it - which you should
But you will have to take the Passenger side rear light out and cut a hole for the bulb to fit as it is blanked over.
This is what I did.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
