I did this job myself last weekend. I had to change the Vento cluster as it was doing 'the dance of death' as Loon calls it. It is pretty much as described above although not quite as easy to do as ScienceVR6 makes it sound.
I had a bit of a struggle with getting the black cover out (the one that sits directly in front of the cluster). The trick there is to put your fingers on top of the dash and push up on the top of the cover with your thumbs or perhaps the other way around, thumbs on top. Imagine trying to grab hold of a shelf of say a book case. When this is out there are 2 screws (one on each side) to undo before you can tip the top of the cluster forward. There was not much slack in the harness to allow me to get my hand behind to unclip the connectors. And you don't have to mess with the air vents.
The only other clue is that the connectors at the back of the cluster have the push in pins in the middle of the long sides instead of at the ends of the connectors like most of the rest of the car.
Reason: Clarification of description.
