Results 1 to 6 of 6
Thread: fitting electric window reg issues... Any advice?
    Jun 2013
    Leichhardt, NSW
    Hi all,
    Installing a replacement window reg and motor on my drivers front and for some reason, every time i go to send the window back up to close, it seems to be getting jammed half way up. It seems to be getting caught on or pulling one of the cables on the way up. After 20 attempts of unfitting and refitting, Still keeps ding the same thing. I'm baffled as to how it is catching the cable.
    Anyone experienced this before? any advice appreciated....
    Dec 2012
    brisbane
    yeah same happened to me. I fitted reg loose and put window up then tightened all bolts havn't had an issue since
    Jun 2013
    Leichhardt, NSW
    Quote Originally Posted by xtfalcon View Post
    Hey mate, thanks for this. to confirm, when you say fitted loose, you mean not doing anything up at all or screwing rails and motor in and leaving the clamps loose that hold the window in? I guess worse case, ill keep the clamps up as high as possible so i can acces them and then drop the window in and try that?
    Thanks again,
    Jun 2013
    Leichhardt, NSW
    ****n **** of a thing. tested it of the car. still only goes up half way, looks like the cables are getting jammed in the motor god damn it.back to he wreckers i go.
    Dec 2012
    brisbane
    I think I did all bolts up but not fully tightened.
    if you got a second hand one yeah probably the reg is no good
    Jun 2013
    Leichhardt, NSW
    yeah, turned out the reg was faulty, guy felt bad, replaced it with a brand spanker.score....
