Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: First post... and some help?
    golfaholic Guest
    I'm so ashamed to admit it, but I can't say I've ever checked the brake fluid on my VW. I've been checking the engine oil, and it doesn't seem to be using it; or if it is, it's using very lightly. The really weird thing about it is that it can be tempramental.. that is, on some days it will run very well on a cold start without me having to let it warm up for a few minutes - and on some other days it will be bouncing around the place so much that I think the engine will jump out. If I apply a bit of power, it seems to overcome it. Im also suspicious about the engine as I think it may have been changed from a diesel engine to an unleaded one; but i really wonder why anyone would do that.
    Hypothetically, if it came to it, and I had to change the engine... how would I go about it, and how much do you guys think it would cost? (of course I know its different from one engine to the next, but I'm guessing most golf models can fit into the CL engine bay?)
    I might take it into a motor mechanic once my exams are over for uni and see what the problem is. Do you guys know of anyone who specialises in VWs around the Newcastle area?
    Thank you all by the way, I'm learning lots already. And I'm still hopeful that I may be able to get "Angus" better yet.
    golfaholic Guest
    Quote Originally Posted by william
    possibly bad fuel mixed with paint thinners u know these vehcle take premium fuel they state it on the flap
    oh yeh of course. always used BP unleaded 95 RON. Thanks though, thats a good tip someone might stumble upon when doing a google search some day.
    Camden, Sydney
    There were bugger all diesel Mk3 CLs in Australia, and no-one would change a diesel to a petrol.
    I reckon its either the thermoswitch on the engine that controls the coldstart. Its on the water outlet in the front of the engine that goes to the top radiator hose. The sensor has 4 wires coming out of it. Next time the car is playing up, disconnect the plug and see if it makes any difference. If it improves when you disconnect the sender, you need a new one. Its very common on Golf CLs and Seat Cordobas and is an easy fix.
    If its not that, I`m thinking headgasket. Does steam or water come out of the exhaust? Hold a piece of paper or your hand about 5cm behind the exhaust pipe for 30 secs and see if any black wet spots appear. Head Gasket is not that big a deal and is easier and cheaper than a new engine. Golf engines last for 300,000kms plus easily, unless they are run with no oil.
    Give us more info and we`ll try and help.
    golfaholic Guest
    Thats amazing. I wish I knew this much about cars... I actually DO get water coming from the exhaust. What does that mean? I will try and disconnect that plug and see how it goes. I will let you guys know. I'll also try to get some pictures of the engine and the car or a video of the start-up so you guys can see what happens.
    Camden, Sydney
    Have a look on the underside of the oil cap and on the dipstick. Is the oil black, or like curdled milk?
    Apr 2006
    Melbourne, Victoria
    Hydrocarbons + oxygen = carbon dioxide + water (+ some other nasties)
    Water in the exhaust of a cold car is normal as it is a byproduct of combustion. When the exhaust system heats up, all the water from the combustion process vaporises by the time it leaves the exhaust tip.
    I wouldnt worry about moisture leaving the exhaust of a cold motor. Check for loss of coolant or bubbling in the radiator/filler bottle when the motor is running.
    If you are loosing coolant without having a puddle under your car then it is probably ending up in your combustion chamber and out the exhaust and a head gasket/cracked head is the culprit.
    hope this helps
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    golfaholic Guest
    Had some time to check out the car today. The brake fluid is fine, and hasnt moved at all. The coolant is ok when the car is warm too. I let it warm up for 10 minutes and held my hand behind the exhaust and I just had a lot of moisture and what smelled like smoke... nothing that really smelled anything like oil. But occasionally... probably every 40 seconds, I would get some smoke. I'm thinking its the oil thats to blame. Any tips on what to do now? Have a great day guys.
    golfaholic Guest
    Quote Originally Posted by Golf Loon
    oh forgot to mention that under the cap the oil was black. What grade oil should be used in the golfs? 10/30?
