Originally Posted by
Special Air Service
Headlights sorted.......on to the next fix up.
The starter motor had been growling a little, so I pulled it to give the planetary gears a lube job. (Pain in the arse that you have to support the engine to remove the starter :mad: )
Pulled the outer case off the starter & the hard plastic ring gear just disintegrated into my hands.......no wonder it was growling, it was slowly eating itself. New starter required. :facepalm:
Brand new run from about $450 - $800 depending on brand.........Camden GTI to the rescue with a 2nd hand unit $165.
