Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Finally showing her some love
    Sep 2014
    Grind the head of the bolts off
    Mar 2009
    gold coast
    If I grind the head off, how will I then get the threaded part of the bolt out?
    Dec 2013
    Drill it out?
    Mar 2009
    gold coast
    Yeah ok, that sounds like a lot could go wrong. I read you can weld a nut on with a couple tack welds and use that to take them out. Anyone done this? Or is that a worse option?
    Dec 2013
    Quote Originally Posted by jazzvr View Post
    Would it be possible to use a screw extractor?
    Apr 2006
    VW Race HQ - Sydney
    Dont drill the bolt . Use a grinder with a thin blade and cut a t vertically and horizontally then use a hammer and chisel to undo it . If you take the whole head off Ive found the thread comes out easily as its usually the head of the bolt the locks itself in . Also dont be afraid to spray wd-40 or equivalent on it . Lastly with the bolts do they have a 17mm head on them or are them m10/12 internal and round on the outside ?
    Bug_racer supports the rebellion of the euro revolution
    Nov 2014
    I used some vise grips, it was a bit tedious, but there was definitely enough to get a firm hold of.
    There's a couple of photos in my thread here.
    Mar 2009
    gold coast
    Quote Originally Posted by Bug_racer View Post
    They are the hex bolt ones that are round on the outside. Does that make a difference?
    Mar 2009
    gold coast
    For any one wondering, I ended up just hammering the triple square bit into the bolts and it worked quite well lol
    Mar 2009
    gold coast
    Hey guys, I just remembered when I took the intake manifold off every second runner was fouled. What the hell does that mean?
