What kind of fuses are you talking about dude? Surely you don't mean the 10a, 15a, 20a and 30a ones you can get from any petrol station...
your rear windows sound typical of regulator failure. You can source some brand new window regulators from places overseas or from VW here, or you can buy second hand ones that are still as prone to failing as the rest of them. I've bought two second hand ones and one has failed, so it's a very hit-and-miss sort of thing.
If your ABS comes on every now and then, it could be a few things...your controle module could have a bit of a bad connection with all the soldered joints, in which case you'd need to take it out and have a look. But you're doing the right thing by checking the sensors on the hubs first
Running temps on mk3's vary a bit with each car. So long as your coolant temperature needle doesn't go past 5/8ths your car is normal.
I would have pointed the finger at a hole in the exhaust for number 2 lol..but if it's intermittent then I'm not sure.
