oh man I hate rattles....as soon as you fix one, another one appears..... but with regards to that, it's hard to tell the location of it without actually being there.. sounds like metal on metal though, so perhaps a nut or bolt has wiggled loose...can't think what's behind there
looking at my vf mounts, the front and rear mounts are the same, but your engine does look a little wonky? how's your trans mount? is that ok? maybe that's dropped?
and is that a plug under the tape? can't make it out :/
what's the mod plate for? is this a converted 2door vr? thought it was an import?
My 0.5's made my engine look similar to this. I did the trans mount as well. Guess it could be normal?
Got the stage 1 trans mount as well and it seems fine.
The taped up thing looked similar to the speed sensor but I don't remember it being a plug - it's been a while.
And the mod plate's for being a personally imported vehicle.
I might just forget about the rattle for now as the weather's getting warmer so it's hardly coming up. Also might get a g60 trans mount from dubaddiction to ease up the vibrations, I heard that's the source of most of the vibration.
Still open to ideas for the rattle, especially if it's accessible from the firewall or maybe a common bolt back there that's echoing through the vents.
thanks so far guys
'94 3dr vr6
- You may not post replies
- You may not edit your posts
Forum Rules
