Results 1 to 5 of 5
Thread: Faulty ignition module?
    Apr 2006
    Thumbs down Faulty ignition module?
    Just to add to the problems we MK3'ers have had over the past few days... just had my car serviced @ a VW specialist... car felt good all day.
    But then!...
    Car wouldn't start... the engine was cranking up strong (so not the battery) but wouldnt kick over and actually start up... no spark coming from the plugs. Tested with screw driver
    Traced the leads up to the module and theres black gooey stuff coming out of the module. This should be the problem right?
    Is this a common problem? Expensive? Help!
    Lucky the Beeza GTi hasnt sold and i still have a car eh...
    VW Golf MK3 1.8L
    Mini Tanks
    If you are talking about the ignition coil, it will be the same on the Ibiza. Swap it over and see if the car starts. They are quite a common failure.
    Apr 2006
    Arh yes!.. defintely worth a try!
    Do you have to disconnect the battery for this type of work?
    VW Golf MK3 1.8L
    Mini Tanks
    Apr 2006
    Cool.. thanks!... will try tomorrow
    VW Golf MK3 1.8L
    Mini Tanks
