Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Fans aren't turning off
    Mar 2014
    Bundoora, Victoria
    Exclamation Fans aren't turning off
    When I leave the car and take the key out both fans start.
    If I put the key back in both fans turn off.
    The car can't be hot as it's a short trip and it's bloody cold outside.
    Help.
    Past - '95 VW Golf MK3 VR6
    Mar 2014
    Bundoora, Victoria
    Oddly enough when I opened the door and took my car charger out the fans turned off.
    But I have noticed lately that the fans seemed to be running longer than usual after turning the car off.
    Could it be just the charger I bought causing something? It only just started happening recently.
    Mar 2014
    Bundoora, Victoria
    So still have this weird problem. Some kind of franken-fans.
    Mar 2014
    Bundoora, Victoria
    They do turn off after a while, just odd why they even turn on in the first place even on such cold nights.
    Mar 2014
    Bundoora, Victoria
    After 10 minutes they turn off, do I have a faulty sensor somewhere?
    Mar 2014
    Bundoora, Victoria
    Replaced the 5A fuse that is part of the fan relay module because it was blown. No change.
    Dec 2006
    Kilsyth, VIC
    I had lots of fan issues with my VR6, I would mostly get high speed (and not the lower speed) and always had the thermo fans run after shut off, even though I didn't think they were needed.
    After much screwing around I had a manual switch put in so I could turn them off:
    Thermo Fans running at full tilt
    Then I had AC issues and after a rebuilt compressor and a few new parts (receiver dryer and AC pressure switch) my thermo fan issues stopped.
    Air Conditioning
    Taken from that thread:
    Quote Originally Posted by The_Hawk View Post
    I stumbled across this info on another forum and emailed it to myself today, but forgot the link. Will update when I find it again.
    In short it says that thermo fans staying on can be because of the pressure switch on the AC. Since my system currently has no gas in it, it may very well be that when it does the switch is causing my high speed to stay on... We will see very soon.
    In response to "Why are my thermo fans always on"
    For me, this turned out to be the AC pressure switch. It's located just below the AC Drier on the passenger side of the car, just under the front bumper. Mine was cracked and needed replacing. Once I did that, all was good again. You can remove the switch without discharging the AC system, so you may want to take it out and look to see if yours is damaged. If not, I'd say it could still be that because I epoxied mine and it didn't help. One other thing it could be is the thermostat...but I'm not sure on that one. Check the switch first, as it's easy to get to. If you have a Bentley, its on page 87-14. L8z
    There are a bunch of sensors which can impact the fans (there are 3 or 4 temp sensors on that engine!) good luck!
    (on a side note... Bitcoin???)
    Mar 2014
    Bundoora, Victoria
    Thanks Hawk,
    I'll check the sensors since that looks easiest to do and a sensor probably isn't too much.
    It's little inconvenient when I park my car and the fans are roaring for 10 minutes. Can be heard from inside the house...
    yeah, Bitcoin. I have a small solar array I built as a project and it's connected to some gear that generates Bitcoin that I then use on an EFTPOS card.
    The address there is a donation kind of thing.
    Dec 2006
    Kilsyth, VIC
    It' taking me back a few year for those sensors, the ones one the rad and crack pipe you can change pretty easily, but remember that you're very likely to loose coolant in the process, so if you were ever thinking of a full flush, now's the time!
    As for the AC sensor (which was my issue), I don't recall if that can come off while the gas system is under pressure or not. Mine was done *while* I was having half the system replaced so it wasn't an issue either way.
    As for the bitcoin, Solar + bitcoin generator sounds interesting. Dedicated ASIC unit ticking away? Does it yield very much?
    I played with bitcoin a little bit, but that was a long time ago now when GPU mining was still worth while.
    Mar 2014
    Bundoora, Victoria
    Plugging out the blue sensor makes no difference.
    Taking out the 20A control module fuse while the fans are running turns them off and when the fuse is plugged back in they stay off.
    Not much, maybe a few dollars a month. Getting lots of batteries from faulty UPSes (taking the good ones) so making a big battery bank.
