My expanssion tank looses water each time i drive it, and I basicly have to fill it every 3rd day as the water level falls to the bottom of the tank.
I have now noticed that after a long enough drive to reach normal operational temperature, once the engine is switched off the water slowly overflows out the expanssion tank.
I have seen a way of checking if the head gasket is blown and air is blown into the cooling system, is to have the engine running with the cap off the expanssion tank. I did this and no bubbles it seemed fine, however I let the engine run until it warmed up and the thermostate opened, the water started to rise to the the top of the tank and flow out with a big air bubble straight after. By the time the engine warmed up the water was bubbling vigoursly and lots of water flowing out of the expanssion tank. At this point I turned the engine off. There is no signs of water in the oil system.
So my question is do I have a blown head gasket, or is this normal for the expanssion tank to behave this way because it is a pressurised system and I am running the engine with the cap off. Is it normal to loose coolant once the engine is switched off?
Thanks in advance
