Results 1 to 10 of 20
Thread: Exhaust setups
    Jun 2011
    Exhaust setups
    So, I've been thinking about getting an exhaust system. However, from what i have read is, the corrado is rated at a few kW more due to a 2.36" exhaust and different cat, compared to the golf's 2.25".
    So theoretically, if I ran a 2.36" with a different cat i should see an increase in power, noise and still remain a healthy amount of back pressure. Or alternatively can I run a bit bigger, such as a 2.5, and not lose much down low torque/power and backpressure?
    As for tips I have no idea; I've seen the usual types I.e Remus, Magnaflow etc. I was think maybe the Xforce Varex if anyone has used one?
    What have some of you other VR6 guys done?
    Sep 2006
    West Sydney
    The Varex works well with all types of cars. Useful if you live in an area littered with defect-happy cops (Newcastle hahaha).
    Sep 2009
    I just took the suitcase out of mine to make it sound like a beast, but I was going to go for a 2.5 inch system.
    Some people think 2.25 makes more then the 2.5 but its been proven that 2.5 makes more power across the whole rev range, and on worked motors a 3 inch makes even more still. I was going to try this one TT Exhaust cat back '95-early'99 Golf Mk3 VR6 Full 2.5 w/Stainless Magnaflow Muffler [253 440TM] - $390.00 : Techtonics Tuning, VW and Audi Performance Tuning and Repair Parts
    Dec 2006
    Kilsyth, VIC
    I have a 2.5" and it does open up the range a little, although I have never had the car with the full stock exhaust so can't really comment on a real "before" That said, I went 2.5" in the lead up to a forced induction setup (which is yet to happen).
    You should come down to one of our meets, there is usually a few VR6's around with various setup's for you to see how different things sound
    Jun 2011
    Interesting thanks or the replies.
    So for a full system, I could expect $390 for that cat back $250-$350 for a cat and approximately $200 for the piping from the headers to the cat?
    Sep 2009
    Dont forget you have to add shipping from the US to that, and being a big bulky exhaust system thats likely to be a few hundred.
    I would go with this cat 42 Draft Designs
    And as far as im aware for some reason getting after market headers and downpipe doesnt make any real power difference on the vr6 (except for a couple which are over $1500 each) but if you port out the exhaust manifolds and have the downpipes welded were they meet the flange from the outside, and grind out the weld on the inside and open it up on the inside, you make almost as much power as the one or two good sets of extractors which do make good power.
    Jun 2011
    Of course; I hate shipping.
    My plan was to get a shop to make up something similar in design.
    As for the headers, I was told they were aftermarket, so if anything they would be those $70 fleabay one's.
    Those cats are good, considering they have the sensor mount in built compared to other ones I've seen thus far.
    I'll hopefully get to an exhaust shop tomorrow and will post up what occurs.
    Thanks.
    Jun 2011
    So I require some more advice please!!!
    I took a visit to a local exhaust shop and he said to check out the the oxygen sensor in the exhaust, as running a 200cell cat could cause it to throw engine warning codes.
    So firstly would this be the case?
    Could I rectify the issue by getting a chip or piggyback ecu if this were to be the case?
    Jan 2010
    Rockingham, WA
    Hey, I'm running a Brospeed branch, high flow cat, 2.5" piping with a magnaflow resonator and back box.
    There is a bit of a drone when youre at speed, but I put dynamat in the truck and that has helped a little bit.
    Sep 2010
    Southern Highlands NSW
    i thought the 02 sensor was located before the cat on the VR ???
    if so i cant see why you would have problems
    Polo GTI
    T-Roc R
    Tiguan R
