Results 1 to 7 of 7
Thread: Even More VR6 Dilemmas
    Mar 2014
    Bundoora, Victoria
    Took the car out for a short stint today, round the block.
    It struggles under load. It will hit 5k RPM or so and then it acts like it doesn't know what to do and then I lose power.
    vag-com scans show up 00515, it's been like that for a while.
    But it doesn't always do this, it's quite random.
    Any ideas? Where should I start first?
    I can log some engine data and dump it if you need.
    Past - '95 VW Golf MK3 VR6
    Oct 2012
    https://www.youtube.com/watch?v=iihSDSFkaa0
    Pretty easy diy. Don't know if thats the root cause of your problems though...
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Mar 2014
    Bundoora, Victoria
    yeah, I saw that. Just wondering where I'd buy the sensor, can't seem to find it. It does seem like it's on its way out.
    Edit; found the part number.
    Mar 2014
    Bundoora, Victoria
    Accidentally accelerated while in neutral and when engaged back it kind of stuttered and felt like it wasn't firing on all cylinders. Put my foot further down and it struggled to get past 40km/h (it was a hill but still).
    Restart of engine fixed it.
    Really need to get this looked at after exams, could be coilpack, could be the sensor, getting it checked out will help.
    LAUNCESTON, TAS
    mine did this, i had a ****ty coilpack.
    so i was running on 4 instead of 6
    its wierd that it fixes it when you restart the engine though, possibly another problem.
    Mar 2014
    Bundoora, Victoria
    Found something of concern today, the top left spark plug+lead sits really loose. It came out without any effort, they're not supposed to come out easily right? Could it come loose while driving?
    Spark plugs were changed a bit over 20k km ago.
    Point Cook, Vic
    sounds like a problem with a lead. Most common fault ive seen is a cracked lead that starts leaking spark at higher load/rpm. Cracked coilpacks can cause dramas too especially if they get moisture in them.
    FOLLOW US ON FACEBOOK
