Results 1 to 5 of 5
Thread: Engine jiggle
    Mar 2014
    Bundoora, Victoria
    Engine jiggle
    From a cold start today I revved it a little (just testing) and when I let go and the revs drop they will sit around 1k but the engine will start to wobble. It can be felt through the steering. Revving it back up and letting it drop again does not have the issue go away.
    I have had this similar problem while waiting at the lights on a hill. Put it in neutral because something did not sound right (or feel for that matter) if I had in in Drive.
    I've read that it could be the engine mounts but not sure. I can post a video if that helps.
    Past - '95 VW Golf MK3 VR6
    Dec 2012
    brisbane
    engine mounts and/or cvs
    Jun 2011
    Sydney NSW
    Yes, it's your engine mounts. This is just going through the resonant frequency of what is left of your engine mounts. Normally the rubber will damp out excessive vibration, but if you get tears in the rubber, this can reduce the damping and so you feel it.
    Mar 2014
    Bundoora, Victoria
    Tested again. No jiggle. It goes back to idle smoothly (800rpm) and the engine stays nice and still.
    If I were to get new engine mounts, what would you recommend?
    Oct 2012
    Bfi stealth lines or bfi 0.5s
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
