Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Engine cuts out in VR
    Oct 2006
    Removing the fuel pump fuse just means that theres no air in the system when u do reconnect it. Jack the car up and have a peep urself u should see the fuel filter pretty easily.
    Jun 2007
    Perth
    OK filter has been changed, but I experienced the issue again... maybe time to try new plugs and leads.
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by runamuk View Post
    Plugs and leads are VERY expensive locally. If you afford the wait, try here:
    http://www.germanautoparts.com/Volks...ectrical/275/2
    Might as well grab some OEM oil filters, sump washers and the lead remover tool while your there.
    Check out my post here from when I was thinking of picking up all those parts:
    http://www.vwwatercooled.org.au/newf...?t=8471&page=4
