Hahahahahha!!!!
You have discovered the VR6's anti-thrash mechanism
You need to wait until the oil temp goes over 50c, then you can do whatever you please.
Until then, if you hammer it the ecu will turn off 2 cylinders and if you persist it'll shut down the engine.
I found this out when I tried to pass a truck once after just leaving my house
Have repeated it several times since. Sneaky ecu!!!!
