Results 1 to 3 of 3
Thread: VR6 Swap - Questions
    Aug 2019
    QLD
    I am in the process of VR swapping my 1.8 CL. Everything is good to go but I'm unsure of which wiring I definitely need. I have removed the wiring harness & ABS module wiring that run through the passenger side of the firewall. Do I require any other wiring or can everything else in the existing car be used?
    Jun 2011
    You’ll need the 3 white plugs out of the fuse block and the loom attached to them. Depending on year model the front lights will be apart of this loom (yellow plugs) they will all need to come out of the donor and swap into the CL.
    Aug 2019
    QLD
    Awesome. Cheers
