Results 1 to 10 of 10
Thread: electric window
    Nov 2008
    Arundel QLD
    Thumbs down electric window
    rear drivers side wen't half way up and stopped, hope it not the dredded mk3 golf window motor sh#ting it self/ if it is where is best place to get new one
    Apr 2006
    VW Race HQ - Sydney
    Euro revolution (whitevr6 on here) keeps plenty in stock
    Bug_racer supports the rebellion of the euro revolution
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by migolf View Post
    It's not usually the motor but the regulator mechanism which breaks down. If it's still working importing one from overseas can be an option, especially if you want to grab a few other parts while your there like oil filters and all the other parts which are stupidly expensive locally. German Auto Parts will serve all your needs.
    If it's busted and you need the window fixed now, well then your left with local options. I sourced a new one round $220 or so through Golf Loon in Sydney (off the top of my head so don't quote me on price), although it may be worth checking out someone a little more local since it's a pretty big package which I'm sure is worth a few $$ to ship.
    Unless your getting them really cheap I don't think it's worth going second hand since your just buying someone else's nearly broken part...
    Sadly, as far as I know the plastic wheel that breaks down over time was replaced with a metal part in the Mk4, they just never retrofitted the part to the Mk3 so your still buying something that will break again one day...
    Nov 2008
    Arundel QLD
    no noise coming from window motor
    Oct 2006
    Even so the best way to diagnose is to take it all apart and then test the motor itself. Even if it is just the motor you might as well buy a new regulator so you wont be doing it again for a while *fingers crossed*.
    Nov 2008
    Arundel QLD
    Thumbs down
    Adam from V A Garage tried to source electric motor for window only got quote gen vw $600 non gen regulator $220
    Camden, Sydney
    Then he is not trying hard enough.
    Second hand complete motor and mechanism $150
    Brand new mechanism only genuine VW $250
    Call me if no-one nearer can help
    Nov 2008
    Arundel QLD
    Question
    will try IMPARTS in Brisbane for motor. didn't think it was worth using a second hand motor[Golf Loon] if prone to failure . rather buy new window motor and hope it lasts. or just replace both rear window regulators with manual ones
    Nov 2006
    Central Coast, NSW
    a rebuilt one is going to last the same time as the original. If you are going to have your car for the next 10 years then you will need something better than OEM
    Dec 2006
    Kilsyth, VIC
    Second hand motor is fine, they don't really tend to break, it's the mechanism itself that breaks, so get a new one of those and use your existing motor.
