It is one thing to say that E5 or E10 is "suitable", and another thing altogether to say that it is beneficial for the car or the environment.
Basically, with E10, you will end up using rougly 10% more E10 which negates the substitution of 10% of the petrol with ethanol, PLUS you burn 10% ethanol.
Ethanol might be a renewable source of energy, however this does not mean that it is not harmful to the environment. Overall, the carbon balance sees more carbon released into the atmosphere than is removed during the growing process. The numbers are made to look favourable because the fuel used in the husbandry of the crop is not counted. Crude oil did take energy to form, however it was spread over millions of years. With ethanol it has to be compressed into a few months and so the energy balance is ot in its favour.
Originally ethanol was mandated to support the sugar cane growers, however almost all of the ethanol used in fuel is produced by distilling wheat and sorghum. Then the government fiddled with excise by applying excise to imported ehanol but not to locally produced ethanol.
There are also mechanical reasons against E10, and air pollution reasons. E10 reduces unburnt hydro-carbons and carbon dioxide and carbon monoxide. These are heavily regulated anyway and the quantities in emission controlled vehicles are small. NOx on the other hand triple because of the leaner mixture and higher combustion temperatures, so this is worse for photochemical smog (brown haze). The leaner mixture can also lead to piston and exhaust valve seat damage.
You just need to sort through the hype. It is like the advertisement put out by the Coal Seam Gas (actually methane) industry where they say that you you don't use CSG you will have to generate electricity using "black" coal. They try to promote the image that CSG is colourless whereas coal is black, and black has to be bad. Maybe they would prefer brown coal instead??
Ultimately, you decide whether to use E10 or not. Just make the decision for the right reasons.
