There's a lot of factors that influence the readings you get out of a dyno.
A std VR should output 174hp according to VW. I am not sure what that is in KW but I do know that 110KW is 150hp.
Depending on how close my mental maths and your dyno are, you could be 10-12 hp short of a std output.
That could be down to not having enough air in your tyres, crap fuel, a set of old spark plugs, a throttle that isn't opening all the way, blocked fuel filter, bad injector........
Do you have diagnostic equipment at TAFE? Maybe you can get to work with that and check the ignition and fuelling systems.
