Page 16 of 70 FirstFirst ... 614151617182666 ... LastLast
Results 151 to 160 of 693
Thread: Dylan8's Vento
  1. #151
    Thanks for the input guys. Budget says no atm, so if it has to come out again in 50,000km or so that'll just have to happen. at this stage I just need to get everything in the one car so i can get the golf out of my parents carport before they kill me.
    Stage 1 of parts ordered:
    Engine Block Gasket Set
    Cylinder Head Gasket Set
    Ultimate VR6 Timing Chain Kit
    Throw Out Bearing
    Clutch Release Lever
    Fuel Filter
    Spark Plug x 6
    Pressure Plate Bolt x 6
    Screw x 10
    Thanks to Jrad for putting up with my million parts questions!
    Hopefully do a compression test will come out with ok results and i can get the vento moving soon.
    Stage two will be on to suspension bushes, wheel bearings, engine mounts, mk4 shifter, and sort why the engine is running a little too warm and a general tidy up to get it roadworthy and rego'd. Hopefully a healthy tax return will make this sooner then later.
    Project V VR 666 steps it up a gear
    Only 12months after the vento got dropped off at home
  2. #152
    Q
    Mine landed November 2009 buddy, don't worry you're killing it! Keep it up can't wait to see it, so glad it's black and you're not a noob with stance so it'll look/sound amazing.
  3. #153
    Quote Originally Posted by Mk3 AAA View Post
    Cheers man.
    Still think you should be finishing your beast
  4. #154
    Aug 2006
    Melbourne VIC
    Good form!
  5. #155
    Sep 2010
    Southern Highlands NSW
    Nice looking forward to it
    Polo GTI
    T-Roc R
    Tiguan R
  6. #156
    Cheers.
    Has anyone pulled their original front quarter off before?
    I unbolted everything but it still seemed to be stuck, a quick google search and interwebs check up shows its 'glued' down, i tried to separate the two carefully, but im in fear of bending the panel where it bolts down at the top.
    Any suggestions? or just go nuts
  7. #157
    Point Cook, Vic
    heat gun and some form of putty blade/spatula type thingo to cut through the sealer worked for me. They are stuck down pretty hard though
    FOLLOW US ON FACEBOOK
  8. #158
    Quote Originally Posted by Tim View Post
    yeah it didnt feel nice... should i be applying something there again when replacing the guard? even if its silcon or something...? guessing its there just to stop vibration/movement?
  9. #159
    Dec 2008
    Sydney/Canberra
    Had the same problem with my wreck yesterday.
    One guard practically fell off, while the othe required a little more persuasion.
    Good work on the pair of 3s, plus the Bora.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  10. #160
    Cheers mate, ill be much happier when the Vento VR is running and registered though :p
