*apparently* there is also a greater range of short shift kits avaliable for the mk 4 setup, as opposed to the mk 3 setup.
its been a while...
but plans are to head back to Bairnsdale these coming school holidays, and get the car to a level i can drive it to Melbourne (at a minimum) as parents are starting to get annoyed about the broken looking golf in the carport. and its a bit hard for me to work on it 3hrs away...
While there was lots of other parts I wanted (suspension refresh, hose kits, cv boots/CVs, engine mounts, mk4 shifter etc) but I just cant afford them right now.
So here is what I have on the order list. Any other 'must haves' people think I should get while pulling the engine out?
Thinking either ECS or GAP for my order. GAP kits seem to have less parts then the ECS ones, so not sure if this is a worry or not...
Will hopefully be getting Josh to strengthen the clutch release lever by welding a plate to the top to suit the HD clutch the VR is already running (its already snapped two im lead to believe)
Engine Block Gasket Set
Brand: ES#: 2726 Mfg#: 021198011A
Cylinder Head Gasket Set
Complete gasket set for your 12v VR6
Brand: ES#: 2262 Mfg#: 021198012B
Ultimate VR6 Timing Chain Kit
Complete VR6 chain kit including everything you'll need to do a chain…
Brand: ES#: 8982 Mfg#: 021198501
Throw-out Bearing
A must replacement when you do clutch work
Brand: ES#: 2167950 Mfg#: 02A141165G~LUK
Pressure Plate Bolts - Priced Each x 6
Bolt that secures pressure plate to flywheel, 6-required
Brand: ES#: 263656 Mfg#: N10101001~OE
Clutch Release Lever
Be sure to change this when doing clutch work
Brand: ES#: 272284 Mfg#: 02J141719C
Flywheel Bolt - Priced Each x 10
Used to hold the flywheel to the crank (12v VR6 only)
Brand: ES#: 2636 Mfg#: N90539801
A new waterpump and crackpipe etc maybe? Easy to swap while the engines out, a bit of a pain while it's in I think.
Are you planning to reco the head once its back in Melbourne?
Not sure what headgasket that kit comes with but if you get a mk4 metal headgasket instead of the standard mk3 one it bumps up compression a little bit and is one of the easiest ways to make a little more power out of the motor if you have the head off anyway. Something to keep in mind. Have you read through this thread before VWVortex.com - How to build a relatively inexpensive, reliable, powerful Vr6.. ? Heaps of good info in there
No point in taking the head off at this stage IMO, unless something needed repairing.
The engine works, and we want to keep it working until you get the car up and running rego'd etc.
then later down the track, sureu
oh these are what the car already had replaced by previous owner
Engine has new new thermostat housing with metal crackpipe and new water pump about 10k ago
2.5kg Fidanza Flywheel with replacable steel friction plate
Sachs HD clutch (~40k old)
New Drivers Side Driveshaft (full assembly) ~15k old
New Fuel Pump ~10k ago
