Page 10 of 70 FirstFirst ... 891011122060 ... LastLast
Results 91 to 100 of 698
Thread: Dylan8's Vento
  1. #91
    Dec 2010
    Gold Coast, Queensland
    Haha, yeah commo steeze
  2. #92
    Picked up my vr6 on the weekend. Previous owner was a forum member way back before my time i believe (car still has a VWW sticker out back ). Thanks to andrew for the sale and also fixing a minor bug or two before i picked it up.
    Thanks to Josh and Stu for the lift and assistance!
    So on the cars 20-30min run home we had a few problems with oil and engine temps, both going up above what they should be... also had some problems engaging 5th (dont think i made it to 5th gear on the test drive...?)
    so for the gear changing problem going to bleed the clutch as it seems very 'short' atm and hope that sorts it.
    for the temperatures will be looking at the thermo stat and giving the car a coolant flush.
    the thermo fans only seem to run when the engine is off, so will look into that sooner then later also.
    quick pic this arvo before i left it and headed back to Bairnsdale.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #93
    Dec 2010
    My thermos only kick in when you turn it off, pretty sure that's standard, my engine runs at optimum temp since I replaced the coolant tank and cap, thermostat was then replaced as well.
  4. #94
    Quote Originally Posted by dark View Post
    oh ok!! Interesting, how does that go in traffic though...?
    What were your temps doing before u did the tank and cap? Im pretty sure my tank is newish, alot of stuff has been replaced already.
  5. #95
    Dec 2010
    they used to be a bit over half, now always under half, havent sat in really bad traffic yet but it seems to be good
  6. #96
    Q
    Ah that's a pretty tidy VR6, please pull it apart quickly so I dont have to see.
  7. #97
    Dec 2010
    Agreed, from the pics it's way nicer than mine body wise anyway!
  8. #98
    body wise it is great i hate to say it, even the sunroof works!!
    but a lot of money would need to be thrown at it to get it to road worthy standard/daily usage. this is pretty much the reason the owner was selling it. exhaust it pretty much gone, 1 window JUST works, no AC, no cruise, no lock in drivers door, new rotors will be needed.
    these things don't really effect me.
    It is a bit tired looking in person, but yes, is probably too good to be wrecking.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #99
    its not being wrecked, its being re-birthed
  10. #100
    Quote Originally Posted by GoLfMan View Post
    true!
    who knows. the left over vr parts might make a come back depending on how many working parts i have in the end.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
