Picked up my vr6 on the weekend. Previous owner was a forum member way back before my time i believe (car still has a VWW sticker out back ). Thanks to andrew for the sale and also fixing a minor bug or two before i picked it up.
Thanks to Josh and Stu for the lift and assistance!
So on the cars 20-30min run home we had a few problems with oil and engine temps, both going up above what they should be... also had some problems engaging 5th (dont think i made it to 5th gear on the test drive...?)
so for the gear changing problem going to bleed the clutch as it seems very 'short' atm and hope that sorts it.
for the temperatures will be looking at the thermo stat and giving the car a coolant flush.
the thermo fans only seem to run when the engine is off, so will look into that sooner then later also.
quick pic this arvo before i left it and headed back to Bairnsdale.
