Page 52 of 70 FirstFirst ... 242505152535462 ... LastLast
Results 511 to 520 of 693
Thread: Dylan8's Vento
  1. #511
    headed over to Silver dubs place on saturday for some arch rolling.
    first issue was the removing the factory sealant/deadener in the rear arches and finding the right tool to get in there.
    Once that was sorted we found a issue with the arch roller that it would only take 12mm bolts... some modifications were made and it was mounted.
    heat was added and arches were rolled basically flat in no time. no cracked paint either!
    thought id throw the audi wheels on, only to find they rubbed on the rear bumper under load and turning.
    some quick adjustments were made and the rubbing was reduced to hard cornering, big bumps, and hard acceleration.
    next wheels should be 5mm less aggressive in the back so should be enough to clear.
    fronts are up next and to space the audi wheels out 5mm more, will end up with
    16x7.5et25 205/45
    16x7.5et20 205/45
    also tried to fit the ABT side skirts but its like the skirts are 5mm too short. need to do some shaving of the body deadening/sealant infront of the rear wheels. looks like whoever was working at VW that day was happy to go a little over the top with the amount applied.
  2. #512
    so new V5 starter arrived thanks to Lucky13.
    mine worked when it wanted and was getting a bit annoying as there is limited places to park on slopes.
    when comparing the two the wheel on mine was much stiffer. I assumed it was jammed up as when I turned the key it could be heard trying to turn but wouldnt always happen.
    slapped that in tonight and happy days, started first turn of the key twice in a row.
    I had used genuine wiring and plugs for the fog lights however I thought I got an electrical burning smell last time I used them and one wasnt working all the time. so decided to pull them for the moment and swap in my air ducts.
    Tried to fit up my NA Jetta lip I scored from Jarred, however seems the US lip lug locations is more like a golf than a vento so quick threw the VR one I have already hacked up back on.
    think I found one of the rattles in the front end.
    was a extra hose clamp on one of the radiator hoses, I do recall loosing one a while back.
  3. #513
    Nov 2015
    Looking good, I like the mags.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  5. #515
    Quote Originally Posted by feenix74 View Post
    Cheers. hopefully have something new on in the next couple of weeks though
  6. #516
    Kellyville Sydney NSW
    looks rad on the Audi wheels dude, love the taillights as well
    Passion Garage
    - Grab Stickers/Merch - We can also source parts, refurb wheels, install Coilovers -
  7. #517
    Cheers, something different for now
  8. #518
    Jan 2010
    Melb Westsideeeee
    When are you getting some proper wheels on the dyl?
    Also I really dig the little ducts/vents
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  9. #519
    Quote Originally Posted by GeorgeMK1 View Post
    3 sets being polished, two sets about to be painted and another waiting on bolts, soooooooon
  10. #520
    Dec 2013
    Wheel whore haha
    Sent from my F1f using Tapatalk
