will do dude, cheers!!
went to swap the wiring in the doors, turns out where the vacuum line runs through the plug is different.
no worries I thought as I also grabbed the lines from the golf too.
tried to remove the old vac line and cracked the housing behind the door hand, bugger! not sure where to go next. so frustrating.
Might block that line for the moment and leave the door locked, atleast see if I can get the power windows working again.
- You may not post replies
- You may not edit your posts
Forum Rules
