Page 44 of 70 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 698
Thread: Dylan8's Vento
  1. #431
    Jun 2011
    Needed to be hulk. Cenny coast spec.
    That is the first photo of a vento front I've ever liked!
  2. #432
    Good thing it's on a Vento then ha.
    Will look even better when it's had a wash and more cool bits added.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #433
    Anyone got a pic of a early aussie mk3 VR fuse box in relation to the relays.
    Think a few of mine are up the piss but getting a number of results pending what country I search
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #434
    Jan 2011
    Rooty Hill, Sydney
    Go to your local dealership with the vin, they can give u a printout of your fuse box showing what's what
    Cars looking tops btw
    Garage:
    VR6
    XR6
    R36
  5. #435
    cheers!
    so fuse box sorted and back in.
    fuel issue was all to do with the after market alarm, they had used genuine vw plugs which threw me off when tracing wiring.
    Now have issues with none of the windows/mirrors are working.
    3 of 4 work via key in the door, and the switches are getting power, but they dont want to move via switch.
    bit of research pointed to the wiring between the doors and pillars.
    sure enough, one side had split the power and ground wires basically in two (the side not working with key in the door), the other side had cracked. both front looms seem to be ok however.
    seems the wires/shielding gets very brittle, and the back doors on the vento look like they have had minimal use prior to me. so guessing on the movement since iv had it has worn them out.
    wiring in the rear door of the golf was ok from memory so will probably steal that when I get home.
    was planning on pulling it out to add speaking wiring to the factory locations anyway
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #436
    Gave it a quick wash just to remind myself its a black car.
    needs a serious detail.
    Anyone ever sourced new rubber seals for their mk3? need to replace the ones on the rear window.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #437
    also picked up a V5 manual box.
    now just looking for a tdi 5th and to work out what driveshaft cups I need
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #438
    May 2014
    Newcastle, Australia
    When i was going to do a v5 box after searching it seems you need 100mm bolt on drive shaft cups from early diesel mk4's, which may be difficult to find lol. Good part is the 5th gear can also be taken from the diesel mk4 box.
  9. #439
    nt
    Got mine straight outta vw. Gave them a part number, and they called their "global offices" and found me some. Price wasn't too bad either.
  10. #440
    Apr 2008
    NSW
    I need to get some rubber seals for my rear window too.
    Im also missing the rubber seal for the front windshield which seals it from the rain tray.
    Dyl if you end up ordering, let me know i'll get in on that with ya.
