Page 42 of 70 FirstFirst ... 32404142434452 ... LastLast
Results 411 to 420 of 693
Thread: Dylan8's Vento
  1. #411
    May 2014
    Newcastle, Australia
    peoples thoughts on leaving it there if I get longer bolts?
    cant see it would hurt a gasket in there other then the pickup being a touch higher off the bottom of the sump
    Sure it would be fine. Can you explain the unable to torque problem? Sumps have such a low torque anyway. How would longer bolts help?
  2. #412
    I think because the gasket thickness added to the thickness of the mk5 sump means the bboltsare only just touching thread then when I'm torquing it up the first thread is letting go. So longer bolts should mean will thread up properly
    Me adding the gasket was like putting a spacer behind a wheel and running stock length bolts
  3. #413
    Jan 2011
    Mt. Waverley, Victoria
    Everything relates back to wheels
    '95 Golf VR6 Colour Concept
  4. #414
    Hahaha I was going to draw it. Thought it would make sense to most people here explaining it like that. Will hopefully get some new bolts. So keen to get this pos driving again
  5. #415
    May 2014
    Oh right gotcha, the r32 sump is alloy as well so would be thicker anyway? If you havnt refilled with oil I would say take it out and use a gasket sealant and longer bolts without a gasket. I used gasket sealant on my vr steel sump and it is yet to leak.
  6. #416
    Well it's either longer bolts or gasket out. Don't need to do both.
    I'm thinking I'm going to give it a go with longer bolts and gasket. Can't see any harm in the gasket being there other then the pickup not been right at the bottom of the sump. At worst I waste 3$ on bolts. Would much rather do that then scrape all the sealant off and clean everything again
  7. #417
    Sep 2006
    West Sydney
    Would also mean you've upped the amount of oil the motor can take (though it would only be a few mL). Not a bad thing!
  8. #418
    yeah ~5mm for the gasket over the sump area shouldn't be a whole heap, plus it wont hurt having more as you said.
    picked up longer bolts for the sump this morning.
    my new valve steam seals arrived yesterday, but freaking out about installing them. would be so much more comfortable with the head off. bit worried about making each piston TDC and without even looking im thinking its going to be a pain turning the engine with it in the car
  9. #419
    R32 sump back off.
    found out I needed to drill the baffles also to clear the dipstick.
    gasket off
    resealed, seems to be holding oil 1 week on. will see once it gets some heat into it
    fuse box is half back in.
    Gear box brace back in after doing some cutting.
    valve steam seals and itll be good to go for roady and rego.
    KEEEEEEN
  10. #420
    Apr 2008
    NSW
    Can't wait to see it on the road mate!
    Have u installed the 02J shifter linkages? If so, was it difficult and can u feel a difference immediately?
