Hi Dylan,
You want to get an old spark plug then drill straight through the middle of it. Once thats sorted you need to get a small hose and clamp and put it over the ceramic section of the plug clamp up and connect up to an air compressor than you can pull the springs to do the seals with compressed air holding the valves shut. You'll only need around 30psi. Don't let the reg run over 40. Make sure the piston is on top dead too and manually brace the crank pulley with a spanner against the ground, subframe or whatever.
For the springs removal you need a lever style tool like this - Amazon.com: CTA Tools 2235 Overhead Valve Spring Compressor Kit: Home Improvement
Hope that makes sense.
Cheers,
Patrick.
