Check all the plugs on taillight end. They wreak havoc on the system somehow
Still in btown, it'll be in Melbourne within two week![]()
Alignment is done.
Got to drive it at speed and is fine on the road other than indicators, sticky brake pedal (lights don't turn off sometimes until I lift it with my foot), and due to the clutch I can't seem to get 5th without a bit of rev matching. And I get some grinding when turning right... I assume this is a left wheel bearing?
Spent a few hours filling the boot with parts I'll need to finish it once in Melbourne. Mostly interior trims etc.
While installing some vac lines I noticed the Vento washer bottle is different to the vr golf one. Golf having a vacuum line coming from the pump where the 2lt Vento one didn't... any ideas?
Build has come such a long way! Looks great! Quick question, not exactly in regards to your build but are the golfs and vento front ends basically interchangable , do you just need to change lights grill and bonnet, or front panels too?
As above. Just the 3 parts.
There is meant to be some differences in the bumper but you don't need
