Page 69 of 70 FirstFirst ... 195967686970 LastLast
Results 681 to 690 of 698
Thread: Dylan8's Vento
  1. #681
    Q
    Still looking sick!
  2. #682
    Not much to update.
    Finally slapped the 312mm on the front.
    Currently running green stuff pads with generic rotors but hoping to find some lighter rotors (prob 2 piece) to try and match the weight of the 288s I had on previously.
    Before and after
    Sent from my HTC 2PZC100 using Tapatalk
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #683
    Not much happening in vento land.
    A covid19 lock down or two ago waterboy and madglf3 came to help push the brake pedal and turn the brake bleeder nipples.
    Rear bias backed off and supports under the beam
    Brake pedal feel was the best I think it's been since I have had the car. Rolled it out ready for a shake down and pad bed in session, casual first to second gear change and no power...
    Pushed the car back and couldn't spot or hear any problem, freaking out clutch or gearbox input I wanted to cry.
    Went over some stuff, not much luck, about to give up and then noticed a tiny bit of day light showing through the drivers shaft.
    This was the result...
    No idea why there was no rattling or banging or horrible sounds. Made me completely overlook driveshafts.
    So much abuse, pot holes, hooning and driving at speed and then it lets go just rolling at walking pace.
    Sourced a used oem shaft, going to give it a refresh and fingers crossed can hit the road.
    Fitted up the new bootlid (desperate for a polish) and have a new bonnet waiting for a second set of hands to fit.. Some PDR on the roof and it'll be almost hail free
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #684
    Sep 2021
    Drouin, victoria
    Hey mate, found you through a mate who is also local to this kind of area, he reckons you might be able to help me find a second hand rear left window reg and motor for an Mk3. Anything and everything is appreciated! Love the work and projects brother!
  5. #685
    Quote Originally Posted by Jb95 View Post
    Hey mate,
    Sorry for slow reply. Missed this one.
    ahhhh I dont think I have any spare motors anymore. Best bet would be the wreckers.
    The regs can be had pretty cheap new on ebay etc, so I wouldnt muck around with a used one.
    If its just the glass clamp in the reg thats let go you can easily repair it with some cable ties and a electrical butt connector, I have one like that in my car, usually last 12months or so before it busts again. Seems to always break mid drive back from a show for some reason so I end up repairing it road side.
    if its the wheel or wire look at a replacement
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #686
    Mixing it up until I find a new vento bonnet.
    Golf bonnet and grill from the vr6 doner
    Pwzo/hella smoked dual chambers
    Nos kamei grill extension
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #687
    Some wheels I've had stashed away forever coming out for a bit of a hot wheels vibe.
    Thanks to the boys that got me the models! Thinking I'll paint one black to match my vento
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #688
    Jun 2011
    How good is a correct front sedan.
  9. #689
    Look, its a backwards step... but fingers crossed the light output is slightly better
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  10. #690
    New temporary wheels
    OZ racing futura monoblocks, I feel they have another name but can't recall
    17x8 205/40 17x9 215/40
    Need to lower the front a smidge.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
