Page 55 of 70 FirstFirst ... 545535455565765 ... LastLast
Results 541 to 550 of 698
Thread: Dylan8's Vento
  1. #541
    More mk3 hangs thanks to Dart
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #542
    Vento seems to have started a terrible idle. Starts off as a bit of a miss or vibration, after 10 seconds or so it turns into have a wild over sized cam.
    Feels ok once on the accelerator. Any way of testing the idle control valve without a vagcom?
    I unplugged the maf and it didn't seem to make any difference
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #543
    Found the solution to the above. Missed a hole in the hose.
    New bushes in thanks to sneaky Pete, now to install the beam
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #544
    Added the vr6 fire wall heat shield.
    What a night mare with motor in and brake lines plumbed in, hopefully keeps the floor and tunnel a touch cooler
    Fitted my oem coolant sensor cover finally
    Was going to fit my neuspeed strut brace, but it fowls on the coolant bottle, not sure if this is because I'm running a 2Lt one.
    Found and fitted a oem battery cover. Looks so much neater.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #545
    Nov 2015
    Good to read you are making progress.
    Really wish I had not thrown out my oem battery cover years ago.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  6. #546
    Cheers!
    Yeah I didn't even realise I had one until I stumbled across it at my parents house looking for other parts.
    Took the Vento out last night and so far so good. Floor and tunnel stayed pretty much cold, will see if that's still the case on a hot day when getting driven harder
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #547
    Jun 2011
    Cheers!
    I'm sure there's another culprit.
    My stripped mk3, no fire wall shield, rubber mat on inside removed as well as missing grommets in firewall was never 'hot'
  8. #548
    Hmmmmmmm. I'll take it for a hoon on the weekend.
    I found my other stock cat so might swap that over too and see if it makes any difference
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #549
    Aug 2006
    Melbourne VIC
    Exhaust manifold studs?
  10. #550
    Will suss those when i do the new exhaust manifold and down pipes
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
