Page 50 of 70 FirstFirst ... 40484950515260 ... LastLast
Results 491 to 500 of 693
Thread: Dylan8's Vento
  1. #491
    so cup kit in. rear first while I waited for some spring compressors for the fronts to arrived.
    bushes were shagged but didnt solve the clunking, think it may be the vertical part of the rear seats not sitting tight in the roll over connector at the bottom. Hopefully get some rubber in there to tighten it up.
    took it for a brap in the hills with silver dub, went well i think. made some nice induction noises off the big trees.
    finished the fronts off tonight, snapped some pics as it was getting dark so please excuse the pictures
    hopefully the front will settle a bit more then off to another alignment.
    then some wheels.
    bit of a teaser of another set on the way
  2. #492
    Jan 2010
    Melb Westsideeeee
    She's aliiiiiiveeeeee yay.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  3. #493
    Munno Para West Adelaide
    Did a drive to the northern suburbs to pick up a cup kit thanks to sneaky pete.
    Hopefully bring it down a touch while firming it up and I can throw the new strut top bushes in to stop the horrid clunking from the rear
    Does approx 3k rpm in 5th at 100km/h so similar to what it was doing in 4th with the VR6 box in. Will be needing a tdi fifth gear for sure
    Guessing the v5 box has different gear ratios? Tdi swap is a common thing Ive seen lately!
  4. #494
    Yep heaps different.
    Needs a tdi 5th or a 6th gear for sure. Fine around town but will suck at 110km/h
  5. #495
    so another alignment today and turns out something is bent in the front end.
    I suspect the hub/spindle as the first alignment I had didn't pick up on it.
    3deg camber is the best I can get out of the drivers side, where left is fine and will go back to zero camber no worries.
    got both set to 3 deg for the moment, will sort it out later on
  6. #496
    Nov 2015
    Looking good.
    Bummer about the bent bit in the front end. I hope you can find it and that it is an easy replace/fix.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  7. #497
    Cheers.
    yeah just a hub/spindle we think as there was no issue before I swapped them.
    Last night I chased the wiring and found a sensor for the exterior temperature. got it all working but it Fahrenheit so pretty pointless on the run ha
    So found the front passenger tyre was JUST touching the spring base with all the added camber.
    Most of the 3 piece wheels are still being built and the steelies were going to cause the exact same issue as they are the same width, offset and tyre width.
    threw these Audi wheels on.
    had a few issues with the rears needing a big adaptor then planned to clear the hub, and then the tyres not clearing the stock arches (need rolling) so was short lived and I've throw the BBS stockies back on the rear temperately so it can drive.
    Gave it a quick wash this arvo, itching to do a full detail on but I think its going to be more then a weekend job... going to require a few full days I fear
  8. #498
    My new headlight switch arrive. However turns out the globe had blown.
    pulled both switches apart and swapped globes over. bingo.
    now to wire up the front end of the car for fogs.
  9. #499
    Thinking of changing things up to match the number plates better
    Just need to finish my other set of headlights
  10. #500
    Aug 2006
    Melbourne VIC
    About time you changed those altezza como lights out!
