Originally Posted by
dylan8
so was going to have a crack at doing the valve stem seals with the head on.
ended up pulling it off to have a look at a few other things.
sure enough, no seals at all. idiot.
went to re build the head and realised the tool (second one I got) was still a terrible design even though it was meant for a VR. bit of drilling and customising and had it set up nicely based on the concept of the one I had seen at volkwerk.
so found a little bur and dint on the side of the head that wasnt helping seal up the cooling housing.
bit of filing and got it sealing much better, still a tiny leak though when cold. so hopefully some sealant will help finish it off.
head back on, new gaskets and bolts thanks to Dean. Timed, new rocker cover gasket (was supplied the wrong one first time).
Car came to life, once it had blown/burn all the oil out of the cylinders and exhaust it was clean as! no more puffs of smoke at idle.
So wiring in the rear doors has cracked in the usual spot killing power windows and mirrors through out the car. back in bairnsdale on the weekend I found the golf loom was in good nick so have those ready to go in.
a CV boot has split just from sitting in the one spot the last year or so.
Hopefully CV boot, windscreen, and coolant leak is all thats left for roady
