Page 36 of 70 FirstFirst ... 26343536373846 ... LastLast
Results 351 to 360 of 698
Thread: Dylan8's Vento
  1. #351
    May 2014
    Newcastle, Australia
    Head unit
    And stacker
  2. #352
    Think that's the same as what I have now, Wil check though. Cheers
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #353
    Same HU as mine so all good, thanks.
    Got some bits and Bobs done today.
    Worked out the brake pedal not completely coming off is to do with the plastic Bush in the back of the pedal that connects to the master being broken.
    New one of those hopefully solves the problem.
    Started putting the interior back together and plugging a few more things in. Was mostly done until I realised I had no plug going to the head unit... pulled a fair bit of it apart again, still can't find it. Bit confused what the go is there.
    Gave up when I went to move the bora and found something oily had been sprayed on a few panels and windscreen.
    Can't have nice things.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #354
    Mar 2014
    Bundoora, Victoria
    That cake looks delicious.
    Past - '95 VW Golf MK3 VR6
  5. #355
    Dec 2013
    Quote Originally Posted by stefcio007 View Post
    So true
  6. #356
    Sorted the headunit wiring issue. part of the loom had been unplugged and put in a different box. two plugs into that loom, loom into HU, done.
    seem to be down on the number of screws to put everything back together so will hopefully hit up some wreckers tomorrow and grab some along with a few other bits and pieces I need to fix/replace
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #357
    Aug 2006
    Melbourne VIC
    Few parts acquired and now the dash board wont fall out!
  8. #358
    Quote Originally Posted by Water Boy View Post
    LOL! yes cheers for that!
    new passenger air bag loom acquired as mine was a bit broken (found out there was two styles, just a heads up for those playing at home), few more screws to get the dash together, and a new mirror and base as both mine are dead.
    Few more head scratching things like 'what's this plug' and 'where's this plug' sorted.
    The two screws that hold the dash to the fire wall, does anyone know what the hole under the drivers side screw is? passenger side one has a plug, drivers side looks like it may have had something in it at some stage...
    Picked up thestus old ventos exhaust, RIP. It was a bit better condition then mine, mine which had been dodgied up by the old owner for the previous road worthy.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #359
    Q
    Why not just extend the tips of the VR exhaust?
  10. #360
    Had a after market remus with a massive hole in the back box,
    Don't want to spend money on the exhaust until I'm putting something decent on
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
