Page 29 of 70 FirstFirst ... 19272829303139 ... LastLast
Results 281 to 290 of 693
Thread: Dylan8's Vento
  1. #281
    Still in btown, it'll be in Melbourne within two week
  2. #282
    Jun 2011
    Check all the plugs on taillight end. They wreak havoc on the system somehow
  3. #283
    brisbane
    So my indicators stopped working and I can't work out why.
    Right was working, and when I flicked to left both stopped.
    Fuses look ok. Hazards work. Brake lights work. Wiring looks ok as far as I can see.
    I did read that if the tail light globe holders get a bit crusty they can kill the whole lot?
    checked the relay? i guess the hazards wouldn't work if that was the case although they might be on a different circuit. relays were always an issue on my old vw's and audi's. just saying, it could be worth a shot...
  4. #284
    This is what I was reading. Can take the whole system out without blowing fuses etc.
    I did check the passenger side and it 'looked' ok, got a second set of lights on the way so that'll be a good way to rule them out.
  5. #285
    Quote Originally Posted by guile View Post
    They are on a different relay I think so could be it, I ran out of time to find one matching. I've added it to my list to check next time.
  6. #286
    Alignment is done.
    Got to drive it at speed and is fine on the road other than indicators, sticky brake pedal (lights don't turn off sometimes until I lift it with my foot), and due to the clutch I can't seem to get 5th without a bit of rev matching. And I get some grinding when turning right... I assume this is a left wheel bearing?
    Spent a few hours filling the boot with parts I'll need to finish it once in Melbourne. Mostly interior trims etc.
    While installing some vac lines I noticed the Vento washer bottle is different to the vr golf one. Golf having a vacuum line coming from the pump where the 2lt Vento one didn't... any ideas?
  7. #287
    Jun 2014
    Build has come such a long way! Looks great! Quick question, not exactly in regards to your build but are the golfs and vento front ends basically interchangable , do you just need to change lights grill and bonnet, or front panels too?
  8. #288
    Jun 2008
    melbourne
    Quote Originally Posted by Juzzpc View Post
    Lights, Grille and Bonnet only bud.
    A lot of mk3 guys are running the vento fronts at the moment on the forum.
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
  9. #289
    As above. Just the 3 parts.
    There is meant to be some differences in the bumper but you don't need
  10. #290
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by Silver dub View Post
    I'm considering swapping back to golf front >.>
    But glad to see the progress Dyl! Hopefully it'll be ready by GAD so I can see it in the flesh, unless you take the Bora...
