Page 26 of 70 FirstFirst ... 16242526272836 ... LastLast
Results 251 to 260 of 698
Thread: Dylan8's Vento
  1. #251
    Jun 2011
    Mine is negative at rear.
  2. #252
    Cool.
    They on the motor or washer bottle side of the battery?.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #253
    Jun 2011
    Cool.
    Motor side.
    In theory battery orientation can be whatever your wiring allows. Assuming you are away from the car and going off memory?
  4. #254
    I just find it wired they are different. That's how the wiring was in the golf, but it was a bit of a battle to tuck it under the tray etc, and does seem a touch short on the wires.
    Ordered a battery to suit, at worst if it's too long I'll spin the battery 180 deg to matxh everyone else and ill just have excess wiring
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #255
    I looked at the picture a few pages back. Mine sounds the same as yours.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #256
    New battery purchased .
    Just paid for some stupid rare Vento parts. That combined with new wheels and nations road trip (even though I kept $ tight) it's going to be a month of 2mins noodles if I plan to get the Vento rego'd by mid July.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #257
    Headed home to baby sit the family dog so thought I'd do some touches to the vento.
    Slapped the battery out of the bora in (waiting for the new one to arrive), fired up straight away, up to temp and a quick brap down the rd.
    Keen to get the rest of the 4-5yr old fuel out of it :/
    First up was the window reg. thought this would be a 30min job like it was on Kirsts polo, how I was so wrong...
    First was the door trim. Seems a window had been smashed at some stage (lots of glass in the door) and weather had been allowed to damage the cardboard/timber fibre. Fresh plastic clips were putting too much pressure on the trim. Finally got it off without damaging the desirable vento cards. figured I'd use the working rear from the golf, fitted up and plugged it in and got nothing. Thought it was something with the car as the rear passenger suddenly stopped working too.
    Turns out the golf one was also dead since I last used it, so the good old cable tie and plastic tubing mod was done on the vento one.
    Not sure what's wrong with the passenger side, but it's staying up,so just going to leave it for now
    Waste of a arvo before I scored a thumping headache.
    Plan for tomorrow is wipers in, rain tray on, bonnet on, control arm bushes and a quick wash.
    If I have time and some help from the neighbours, put the golf in the shed (out of mums sight) and vento steps up to the carport
    Hopefully get a quick alignment done on Monday after a surf, does look and drive ok ATM though
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #258
    Aug 2006
    Melbourne VIC
    Careful doing the bonnet by yourself. Get one of ya useless btown mates to help ya!
  9. #259
    Quote Originally Posted by Water Boy View Post
    Will do.
    And cos everyone loves pictures
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  10. #260
    So r32 bushes in the control arms. Found out there was already some poly ones fitted, fronts were ok. Rears even had off centre holes, but passenger side was dead.
    Replaced the sway bar links and ball joints too. Wow ball joints are a nightmare to remove without the proper tool or removing the spindle from the car.
    Found the passenger side link was loose so hoping between that and the new control arm bush it stops the random clunk.
    Tie rod ends look ok so left them, saving the strut tops and bearings til I get coilovers so hoping they will pass roady as is
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
